wrote in message
news:6247189@discussion.autodesk.com...
> A defect was logged with Autodesk on a very similar superimposed profile
> issue with the 09 version.
> John Mayo, PE
> Core i7 920 6GB DDR3
> Radeon 4870HD 1 GB
> Vista64
I have been fighting with this same problem. Here are a couple things that I did to fix it.
First, I made sure that my alignment was completely inside the surface boundary. Originally the begining and ending of my alignments to be superimposed were outside the surface boundary. I fixed this and one of my problem profiles was fixed, but the other one wasn't.
Second, I reversed the direction of my alignment to be superimposed so that it ran in the same direction of the parent alignement. It shouldn't matter which way the alignment runs, but apparently it does, because once this was done the superimposed profile was fixed.
Hope this helps.
I had been having this issue as well bu tI think I found a workaround, at least it works in 2011.
Create a feature line from your aligment/profile you want to project. Then project this feature line instead of the profile. Seems to work.
None of the fixes mentioned worked for me. The alignment is well within the surface boundary, the alignment was already running in the same direction as the parent alignment (I even tried to reverse it to see if it would work), and creating a feature line and then superimposing that line on the profile did not work.
Any other suggestions? I have wasted more time on this that I should be, but now it's really starting to get to me!
Just wanted to follow up and see if this issue has been resolved I've been looking everywhere for a solution to this as well.
