anyone know why Superelevation functionality would be missing from drawing files started from my company template, but it is there in the OOTB template? I didn't create the template. The person that did is on vacation.
If I click on an alignment, the superelevation drop down does show up on the ribbon. If I enter the calceditsuperelevation command the window is rather empt, the wizard button is grayed out, & attempts to add a user defined curve fail.
Can anyone tell me what the templete creator might have deleted to ruin superelevation creation/editing?
It seems like all the AASHTO tables are listed under the design critera settings.
Solved by kcimos. Go to Solution.
2114 SP1
If I draw a 1 segment polyline & create an alignement from it, in the drawing from the OOTB templete, the superelevation functionality is available.
if I do the same in the drawing from the company templete, it is not.
In both cases, having apply desing critera checked or not checked makes no difference
OK, I found the problem:
the alignment type was set to "miscellaneous". If it is changed to "centerline" then the SE functionality is available.
