For the transistion length values, the out-of-box criteria files that Civil 3D provides, there is a simple formula based on AASHTO standards that will calculate the superelevation for a given radius and design speed. If you want, you can create or modify your design criteria file so the superelevation is calculated differently or, you can edit the superelevation after you calculate it (allowing the default values to get you close).
I am trying to use Superelevation wizard to calculate three lane on the left and tree lane on the right side of an alignment. Can you tell me the steps I need to take to accomplish this
