All,
I am using Civil 3d 2013 and I am trying to calculate the superelevation information in which the curve will max at 2%. Is there a way in which the superelevation can be calculated using the superelevation wizard in which a 2% SE is the max? So far it will only let me use the SE for 4% local roads and I have to edit it using the SE layout.
Any advice or steps will be greatly appreciated.
Thanks!
-Lucas
Solved by sboon. Go to Solution.
Rather than using the tabular editor for adjusting superelevation you can do it with grip edits in a Superelevation view.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
The data used for superelevation calculations is stored in xml files here:
C:\ProgramData\Autodesk\C3D 2012\enu\Data\Corridor Design Standards\Metric or Imperial\
With some work you can edit a copy of one of these files to create your own table with the values you want.
