AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 2 (228 Views)
Super Elevation and Horizontal Transitions
228 Views, 1 Replies
02-14-2013 10:45 AM
I need some help with getting a roadway to transition horizontally for a turn lane. If it were straight without super, it would be easy. However, the transition happens in a curve that needs to be super elevated.
I know I can use the lane transition assembly and set it to "change offset and grade" but with that, I would have to manually calc my EOP elevations.
Is there a sub assembly with the ability to use the centerline super elevation data as well as transistion horizontally? Any other ideas?
Using C3D 09
-Tucker McKenzie
Message 2 of 2 (224 Views)
Re: Super Elevation and Horizontal Transitions
02-14-2013 11:05 AM in reply to: t_mckenzie
Sorry, should have checked the subassembly catlog. There is a super elevation with varying width in there. Our standards has a tool pallette that has paired down some of the additional sub assemblies, and it wasn't in there.
Anyways ... sorry and thanks!
-Tucker
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
