Active Contributor
dslocum
Message 1 of 5 (119 Views)
Suggestions needed for template maintenance
119 Views, 4 Replies
02-19-2014 06:21 AM
Does anyone have any suggestions on how to keep the Civil 3D template drawing up to date? As I work in projects I tend to make new styles, layers, layer filters, settings, etc. that I want to be in my template for future use. I know I can save my current project as a .dwt and use it as the template file for the next project, but is that really the proper work flow? Any suggestions or ideas would be apppreciated.
kcobabe
Message 2 of 5 (109 Views)
Re: Suggestions needed for template maintenance
02-19-2014 06:49 AM in reply to: dslocum
If you go to the "Manage" tab, towards the end you will see an import styles button.  Click that and browse to the file.  You can also open the file and your template and switch to master view in settings, then drag and drop the styles.  Both should work.
R10 - 2014 ACAD, 2008 - 2014 Civil 3D, 2010 - 2014 MEP, V8i - V8i SS3 Microstation, ArcMAP
Jay_B
Message 3 of 5 (102 Views)
02-19-2014 07:04 AM in reply to: dslocum
I'd recommend reading the Templates, Styles and Drawings section of the Civil 3D Best Practices Guide.This provides a good overview of template setup and the QNEW variable etc.
Create Templates and place them in a central location on a read only network if others need access.
Then update them with your new Styles & Layers as needed.
Creating and maintaining a clean dwt essential to efficient use of Civil 3D IMO.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
neilyj
Message 4 of 5 (84 Views)
02-19-2014 08:53 AM in reply to: Jay_B
If I create a useful new style/label/layer, I'll copy it to my template for use in the next drawing I create via QNEW.
I tend to keep everything in one template (backed up to Autodesk 360 - at last a use for the Cloud....!!!) but not sure how practical it would be to use different templates for different projects as inevitably the style/label you need is in the "other" template
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
dslocum
Message 5 of 5 (57 Views)
02-19-2014 11:18 AM in reply to: neilyj
Thanks! I'll give that a try.
