AutoCAD Civil 3D General
Active Member
Message 1 of 7 (1,544 Views)
Subtract one surface from another.
1544 Views, 6 Replies
11-24-2009 11:10 AM
Hello all,
I am in need of subtracting Surface A from Surface B to display the surface intersections between the two. I have a geological top of clay surface and a bottom of clay surface where the bottom intersects with the top thus showing holes in a geological clay layer. I am wanting to know if Civil 3D supports the subtracting of two surfaces.
Thank you!
*Terry W. Dotson
Message 2 of 7 (1,543 Views)
Re: Subtract one surface from another.
11-24-2009 12:21 PM in reply to: CAD_Avatar
Don't claim to be an expert, but you should be able to create a 'Volume
Surface', using care in specifying the order of base/compare surfaces.
Then contour elevation 0.0.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
BrianHailey
Message 3 of 7 (1,543 Views)
11-24-2009 12:30 PM in reply to: CAD_Avatar
Terry, if you are just trying to get the intersection of the two surfaces, the order they are added (base vs. comparison) doesn't matter.
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
*Terry W. Dotson
Message 4 of 7 (1,543 Views)
11-24-2009 04:01 PM in reply to: CAD_Avatar
> matter.
True, but todays 'just' is often tomorrows 'first of many', so might as
well build it right today.
Terry
New Member
Message 5 of 7 (884 Views)
11-21-2012 05:49 AM in reply to: *Terry W. Dotson
Terry
When i do what you say, the result volume surface is in the wrong elevation.
Example: my surface "1" is in (+-) elevation 235.600 and my surface "2" starts from 235.850 to 235.450 (it's like a cup), when i do the volume surface, the result goes to elevation 0.0 (+-), and when i do contour elevation 0.0, it gives me the interserction but in the wrong elevation! how do i put this in the right elevation? because what i want is the (surface 1)-(surface 2)
thanks for your time
Ivo Costa
Message 6 of 7 (869 Views)
11-21-2012 07:59 AM in reply to: CAD_Avatar
The elevation you're seeing is the difference in elevation between the two surface; surf 1 minus surf 2. This is what it seems like you asked for. So you have your contour line representing where they intersect and all you need now is its elevation to match the surfaces?
Turn it into a feature line and use the surface from elevation tool.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
BrianHailey
Message 7 of 7 (859 Views)
11-21-2012 08:46 AM in reply to: mathewk
If you don't have a good understanding of how Sites work within Civil 3D, I would recommend that you don't use a featureline, just use the same tool and assign the elevations to the polyline instead. If you want more inforomation on why I recommend this, check out THIS.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
