antoniovinci
Message 11 of 31 (779 Views)
Re: Subdivide a rectangle
10-11-2013 05:47 AM in reply to: mw_in_okc
That sounds exciting, Mike, but... when I paste your code in Qgis Python console, I get a bunch of errors - tried with 1.8 and 1.9 releases.
However, if I try with an italian online Python service, it works brilliant.
Unfortunately the OP is lookin' for something else: he just has hundreds of rectangles already drawn...
doni49
Message 12 of 31 (767 Views)
10-11-2013 07:33 AM in reply to: owenmull
The attached lsp file will do what you've requested.
  1. it does NO error checking.  It will prompt you to make a selection.  It will only allow you to select lwpolylines (not 3d polylines).
  2. it will be up to you to make sure that you only choose rectangles.  This will work as long as you ONLY choose rectangles.
  3.  if you want to keep the existing rectangles go to the bottom of the lsp file and remove the line that deletes them.
Rename the file with an LSP extension -- the web site wouldn't allow me to upload it until I saved it as txt.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Joe-Bouza
Message 13 of 31 (757 Views)
10-11-2013 07:59 AM in reply to: doni49
Wont run fo me
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
antoniovinci
Message 14 of 31 (752 Views)
10-11-2013 08:06 AM in reply to: doni49
Are you kiddin' us, Sir..?
I only got "error: malformed list on input" : please check your code before uploading to this lordly forum, thx.
doni49
Message 15 of 31 (743 Views)
10-11-2013 08:16 AM in reply to: antoniovinci
I don't know what to say.
I had copy/pasted it into acad and it worked (I had two rectangles at the start and after running it, I had 8.  But when I tried LOADING it in, it failed.
Anyway, I found the bug and fixed it.  Just to be sure, I created a new drawing, drew two rectangles and loaded the lsp file via APPLOAD.  It happily draws the rectangles.
And here's the dwg file that I used for testing -- it started out as two rectangles the ones you see were created by the lisp routine.
Don Ireland
Forum links:
Civil 3D General
Joe-Bouza
Message 16 of 31 (738 Views)
10-11-2013 08:20 AM in reply to: doni49
You're getting closer Doni; the OP request the division to be 64 rectangles not 4
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
doni49
Message 17 of 31 (731 Views)
10-11-2013 08:28 AM in reply to: Joe-Bouza
Ouch.  I truly overlooked that part.  That will take some pondering.  But I'm sure it can be done
Don Ireland
Forum links:
Civil 3D General
Member
mw_in_okc
Message 18 of 31 (724 Views)
10-11-2013 08:43 AM in reply to: antoniovinci
The python code as provided is version 2.7, and I have tested it several times this morning. I run the script using IDLE independent of any built-in application console. It can create an 8x8 grid or one as dense as required that fills the original rectangle. In fact, I've added it to my working library.
Have a great day.
-Mike
doni49
Message 19 of 31 (710 Views)
10-11-2013 10:41 AM in reply to: doni49
Ok.  I've updated it to put 64 separate rectangles.  It HAS been tested (using the attached dwg file).
Don Ireland
Forum links:
Civil 3D General
AllenJessup
Message 20 of 31 (704 Views)
10-11-2013 10:50 AM in reply to: doni49
In 2012 I get a malformed lisp error.
Allen
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
