This may not be the correct forum for this question, however I'll post it anyway.
I have created a subassembly using the subassembly composer. The assembly works just fine in creating a corridor, sections and volume tables, however the point markers are showing in all of the section views.
Is there a way to turn them off in the section sheets since they make the sheet very crowded and cluttered. I have attached screen shots of the assembly and a section.
Thanks in advance
Don
Matt,
Thanks for the reply, I tried resetting label styles to <none>, and point codes to Basic or off. Didn't change things. However by going thru "Edit corridor Properties and changing the Object Style to Basic with <None> for label style, the markers did go away.
Sorry I grabed the subassembly and assenbly JPEG's and not the section JPEG, the ones I did attach showed the markers anyway.
Thanks again for your reply
Don
