AutoCAD Civil 3D General
Active Member
ddouglas
Message 1 of 3 (223 Views)
Subbassembly Composer point markers showing
223 Views, 2 Replies
11-21-2012 01:06 PM
This may not be the correct forum for this question, however I'll post it anyway.
I have created a subassembly using the subassembly composer. The assembly works just fine in creating a corridor, sections and volume tables, however the point markers are showing in all of the section views.
Is there a way to turn them off in the section sheets since they make the sheet very crowded and cluttered. I have attached screen shots of the assembly and a section.
Thanks in advance
Don
mathewk
Message 2 of 3 (204 Views)
Re: Subbassembly Composer point markers showing
11-21-2012 03:18 PM in reply to: ddouglas
This depend on if you have named them explicitely in the Comopser. If not, these will be represented by the "Not Coded" (or something like that) styles in the points section of the code set style you have applied to the sections in the views.
If not, assign a no display style to either that code or the default codes also in the code set style.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Active Member
ddouglas
Message 3 of 3 (193 Views)
11-21-2012 05:05 PM in reply to: ddouglas
Matt,
Thanks for the reply, I tried resetting label styles to <none>, and point codes to Basic or off. Didn't change things. However by going thru "Edit corridor Properties and changing the Object Style to Basic with <None> for label style, the markers did go away.
Sorry I grabed the subassembly and assenbly JPEG's and not the section JPEG, the ones I did attach showed the markers anyway.
Thanks again for your reply
Don
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
