Civil 3D Forum
Subassembly - "Uncoded"
3 REPLIES 3
dbussie
7134 Views, 3 Replies
I just tried to create a subgrade surface using the base link.  The surface turned out to be wrong because some of the points in the Lane Outside Super Layer Varying Width subassembly are uncoded.  Please tell me there is an easy fix for this.  Everything I've looked at seems to be programming related (over my head).  Do I need to download a composer for 2014?  I didn't see one on the list for 2014.
Could someone please give me a nudge in the right direction here?  Preferably a fairly easy path.
Thanks!
Desirea
3 REPLIES 3
tcorey
in reply to: dbussie
Hello Desirea,
When you create a Corridor Surface use the Links option. It doesn't matter if some of the points are uncoded.
What results are you getting that make you think it's not working correctly?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sboon
That doesn't sound right.  The base links are at the bottom of the base gravel only.  Try using the Datum links instead.  Typically Autodesk uses the Datum code for the bottom link in all of the OOTB subs.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
dbussie
in reply to: sboon
Using the datum link worked great.  Thanks!
Rail Community
