I have an assembly that includes 3 subassemblies (LaneOutsideSuperWithWidening, ShoulderExtendAll and DaylightMaxOffset). Please see attachment (the section is in superelevation). When I am in superelevation the LaneOutsideSuperWithWidening subassembly is working properly as shown. However, the ShoulderExtendAll subassembly is not changing to match the superelevation of the LaneOutsideSuperWithWidening subassembly. I've tried changing the parameters but cannot get it working. Any ideas what the problem might be?
Solved by sboon. Go to Solution.
It's possible that your alignment superelevation has been calculated without the shoulders, so they always use the default slopes.
Check the superelevation table for the alignment, and make sure that you have values for the outside shoulders.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Is there a way to correct this if the superelevation is already created from the wizard? I may have unchecked that box accidentally but I do not wish to redo the superelevation work as much of it is manual.
Thank you.
Natalie
