Civil 3D Forum
Subassembly Superelevation Issue
3 REPLIES 3
Rainman1
639 Views, 3 Replies
I have an assembly that includes 3 subassemblies (LaneOutsideSuperWithWidening, ShoulderExtendAll and DaylightMaxOffset). Please see attachment (the section is in superelevation). When I am in superelevation the LaneOutsideSuperWithWidening subassembly is working properly as shown. However, the ShoulderExtendAll subassembly is not changing to match the superelevation of the LaneOutsideSuperWithWidening subassembly. I've tried changing the parameters but cannot get it working. Any ideas what the problem might be?
3 REPLIES 3
Lisa_Pohlmeyer
in reply to: Rainman1
This is what our sub-assy is set to and it follows the supers.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Tags (1)
sboon
It's possible that your alignment superelevation has been calculated without the shoulders, so they always use the default slopes.
Check the superelevation table for the alignment, and make sure that you have values for the outside shoulders.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: sboon
Is there a way to correct this if the superelevation is already created from the wizard? I may have unchecked that box accidentally but I do not wish to redo the superelevation work as much of it is manual.
Thank you.
Natalie
Rail Community
