I have created a suite of custom subassemblies in Subassembly Composer and have already edited the .atc and .xaml files within the packet file to ensure that the parameter order is as I want it to be...
The parameter order is still OK after importing the subassembly to my tool palette, however, as soon as I rename the subassembly, the parameters revert back to the original order? Does anyone have any suggestions?
Regards.
Ross.
Solved by RDunkley. Go to Solution.
I have narrowed down the issue slightly...
The parameters are OK as long as I stay out of the 'Properties...' dialog box...
As soon as I go into the 'Properties...' dialog box, even if I don't make any changes the parameter order is messed up! If I go into the dialog box and press 'Cancel' things are still OK...
I guess I will see if Autodesk can sort this one out...
Regards.
Ross.
After working with Autodesk and checking on other users' installations, where everyone else's seemes to work OK, it appears that it is just an issue with my install. I will work around this for now and maybe do a reinstall at a later date.
Regards.
Ross.
