Hi all,
Just a quick query hopefully it is only requires a simple solution.
When i am creating a assembly, the sub assembly parameters for the generic pavement structure is not showing (such as the lane width or crossfall) Other sub-assemlies show these parameters. Is this a bug or is there a way i can turn this on.
I can change the parameters on the properites.
Thanks for your help.
Hello
That seems a bug, try another file and look to update for AutoCAD Civil 3D.
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
The Autocad Civil 3d is upto date. Seems like the codes are missing as well so the corridor does not show up. it is running fine with other subassemblies.
Anyone else having the same problem?
Yes, works for me. You have the ability to add your own codes with this SA.
