AutoCAD Civil 3D General
Message 1 of 5 (379 Views)
Accepted Solution
Subassembly Editing
379 Views, 4 Replies
12-20-2012 04:58 PM
I modified the UrbanCurbGutterGeneral subassembly that comes with C3D2013 to match our local standards.  Came out great and is working.  I copied the Subassebmly, made my edits and renamed it "G-2".  My problem is that when I select the subassembly in the drawing, the properties box still shows it as "UrbanCurbGutterGeneral".  Why is it showing as one name on by Tool Palettes and a different name in the drawing??
See image.
*Expert Elite*
Message 2 of 5 (363 Views)
Re: Subassembly Editing
12-20-2012 09:16 PM in reply to: SDcivil
You need to copy the sub and paste it to a NEW custom tool palette and not into the original one like you have done.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Active Member
Message 3 of 5 (346 Views)
12-21-2012 11:12 AM in reply to: SDcivil
How did you open the subassembly file, What program?. I was under the impression that Subassembly Composer can't open the stock subassemblies.
I have been tiring for weeks to get a modified Gravel Road subassembly to work with SuperElevation properly. It works on a flat area but the shoulder slopes change and the ditch depths change when in superelevated region. I am very new to Subassembly Composer and would like to be able to open the existing Road and Shoulder subassemblies to see how they are configured to accept the Superelevation requirements.
Thanks for any help in advance
Don
Message 4 of 5 (336 Views)
12-21-2012 02:04 PM in reply to: mathewk
Thanks for your reply.  I just cut/pasted saved it over to a custom pallate, as suggested, and renamed the subassembly.  I did a test and attached it to one of my assemblies.  If I next select the curb it still shows up in my properties as named "UrbanCurbAndGutter".
*Expert Elite*
Message 5 of 5 (330 Views)
12-21-2012 02:33 PM in reply to: SDcivil
Ok, I think I know what you're doing.  You get this right?  The "Name" still says Urban Curb...?
This is normal and you can't change it.  When you copy a tool palette tool, you're renaming the tool, not the subassembly.  You'd need to edit the .NET code to change the name of it.  Short answer is you can't do it without lots of unnecessary work.
Matt Kolberg
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
