LeafRiders
Message 1 of 2 (142 Views)
Subassembly Composer - Update existing Custom SAs
142 Views, 1 Replies
11-27-2012 06:20 PM
What's the easiest way to update an existing custom SA once it's in the drawing.
For example i have some coding that I'd like to change and this particular SA is in use 10 times in my file in different ways. I used the Subassembly Composer to create the original custom SA.
It's not as easy as saving the file over top of the existing .pkt file, if it was I wouldn't be here. It seems to be behaving like a block would. I need to redefine the Subassembly in order for it to update in the drawing. How is best to do this and is there any tricks to the process. When do i need to open and close Civil in order to apply the new changes.
Do I need to update the SA in my tool palette as well?  Any and all information that will save me smashing my computer would be great. Thanks. :smileywink:
mathewk
Message 2 of 2 (125 Views)
Re: Subassembly Composer - Update existing Custom SAs
11-27-2012 10:24 PM in reply to: LeafRiders
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Update-Subassembly/td-p/3431467
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
