Civil 3D Forum
Subassembly Composer - Tutorial ?
4 REPLIES 4
7218 Views, 4 Replies
Does anyone know of a website that can provide a tutorial on the SubAssembly Composer? Maybe something in Autodesk University site? I can't seem to find anything and the wiki help is pretty lean on how to get this potentially great tool to work. Thanks Chris
4 REPLIES 4
KMercier_C3D
There were two classes specifically about Subassembly Composer at Autodesk University 2011:
http://au.autodesk.com/?nd=class&session_id=9196 and http://au.autodesk.com/?nd=class&session_id=9212
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
in reply to: KMercier_C3D
Thank you so much for the links! Looking forward to the tuorials. Best Regards, Chris
peterfunkautodesk
There were two classes at AU last year on this, one by myself and a very detailed class by Kati Mercier that you should check out. We both did an hour of how to get started with Subassembly Composer.
We also have a number of sample Subassemblies on the Help Wiki site that you could look at for starting points.
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
phunter7
Wiki help....Autodesk's way of saying "we're charging you more, doing less and write your own **** manual."
Rail Community
