Civil 3D Forum
Subassembly Composer Help (Peter Funk?)
13 REPLIES 13
Message 1 of 14
ccookusi
3022 Views, 13 Replies
Attached is a shoulder sub I am trying to complete.
My sticking point is defining the "slope", which I want to be an input parameter, from P6 to P7.
L7 needs to tie to this slope while maintaining the superelevation.
Any guidance would be appreciated..
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
NVMe Samsung SSD 960 Boot
16 GB Ram
13 REPLIES 13
Message 2 of 14
KMercier_C3D
in reply to: ccookusi
For P7 use an Intersection Point.
Type: Intersection: TwoPointsSlope
Point1: P6
Slope1: UserSlope
Point2: P5
Slope2: L1.slope
You will then define the two links from P6 to P7 and from P5 to P7.
Hope that helps! Sincerely, "Not Peter Funk"
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 14
ccookusi
in reply to: KMercier_C3D
Thanks Kati..
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 4 of 14
ccookusi
Kati,
How do you modify the sub to use any of the super choices?
As I have it, it only uses the right outside shoulder.
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 5 of 14
KMercier_C3D
There are lots of different ways you can do it depending on what you are looking for. Do you want the user to pick what they want? If so you would need to have an Input Parameter that would give them the ability to pick (either using the Superelevation type that already exists or define your own Enumeration). You may also want to incoporate the SE.HasLeftSO=true (or whichever you are looking for)  to confirm that the superelevation exists before trying to use it.
Pronouns: She/Her
Message 6 of 14
LeafRiders
I can't seem to open this .pkt file in SA Composer 2012. (Is this maybe a 2011 or 2013 file)? Could someone please post a screen shot of the preview screen so I can see what you're talking about. I think I have a similar issue. Thanks in advance.
Message 7 of 14
ccookusi
It is a 2013 Subassembly.
Attached is a screenshot of it.
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 8 of 14
jnjhuz
Hi Peter,
I saw online that you had a variable slope daylight subassembly for 2016. Unfortunately, I'm using 2014. Would you have something similar for 2014 or know where I can get it?
Message 9 of 14
KMercier_C3D
in reply to: jnjhuz
@jnjhuz you can create this pretty simply on your own. You just find the ratio of where you are in the region and ratio the start and end values accordingly. This is also covered in my AU2017 lecture mentioned in my signature line.
Pronouns: She/Her
Tags (3)
Message 10 of 14
jnjhuz
I don't know if I can build a subassembly with parameters in 2014 but I will look into this. Thanks!
Message 11 of 14
KMercier_C3D
in reply to: jnjhuz
Once you make the pkt file this will allow you to vary any input parameter in any stock Civil 3D subassembly. You will insert this subassembly before the one you want to vary in Civil 3D and then set the Start and End values that you want. Then on the Construction tab you will go to the stock subassembly that you want to vary and check the checkbox for Use Parameter Reference and from the dropdown you will select this varied output parameter.
I don't have 2014 anymore to test but it should work, I am pretty sure all of these features were available then.
Pronouns: She/Her
Message 12 of 14
jnjhuz
I don't have subassembly composer.
Message 13 of 14
toposakiki
HellO katy, do you have access to the pkt file? is this something you can share?
If not whats SA.islayout?
thanks
SA
Message 14 of 14
KMercier_C3D
in reply to: toposakiki
PKT is attached (delete the .zip at the end of the file name)
SA.islayout just governs how the subassembly behaves when in layout and not run as part of a corridor. Otherwise it doesn't know what value to use when you are adding it to an Assembly.
Pronouns: She/Her
Rail Community
