I have created a decision; I need to check whether an offset target is set and valid. Here is my code. I believe it's correct, but it gives me that red dot saying it's not. I've tried...
Yes
'Yes"
True
"True"
I've tried simply OffsetTarget.IsValid without yes or true.
Any ideas?
Solved by KMercier_C3D. Go to Solution.
Try LaneW.isvalid
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Kait, I might as well have your direct email. You seem to be the one with all of the answers 🙂 Thanks, that worked.
