Civil 3D Forum
Subassemblies at different slopes targeting each other
6 REPLIES 6
jon_b
8719 Views, 6 Replies
I have a ditch and a road that need to follow separate profiles but be integrated with each other as a single corridor and the ditch's 3:1 slope needs to meet up with the road's 2% slope.  Is it possible to have the two subassembiles target each other without having to create a dummy surface or a feature line for targeting to?  Attached is a snapshot of the road and ditch configuration.
6 REPLIES 6
Jay_B
in reply to: jon_b
Daylight Basin and Daylight Basin2 support profile or feature line targets and could be attached to to the edge of road / shoulder.
Then the extra Assembly marker wouldn't be needed as it would all be tied together in one single corridor. Look at the help for these 2 subassemblies.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
jon_b
in reply to: Jay_B
My ditch will be at a grade of ~0.15% with periodic drop structures at 10% to correct for changes in elevation, while the road is to be a minimum of ~1.2m above original ground, wouldn't the DaylightBasin subassembly adjust its horizontal location to meet the elevation target and introduce jogs?
Jay_B
in reply to: jon_b
If I'm understanding, yes the toe of the ditch would move in and out from the edge of road due to the variation in ditch grade but I thought you were asking for a 3:1 slope, not a variable one. If you do use the DaylightBasin, it helps to specify a very small number for the depth when controlling ditch depth with a target. Otherwise some portions of sub won't tie etc. depending on the terrain.
C3D 2018.1
C3D 2016 SP4
sboon
in reply to: jon_b
If you wanted to maintain the 3/1 ditch foreslope and the 2% shoulder slope, and allow the intersection point to move as the ditch profile changes then LinkSlopesBetweenPoints may be appropriate.  In this case the ditch width parameter would be zero.  Set a marked point at the edge of the lane then attach the sub to the inside edge of your ditch.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
jon_b
in reply to: sboon
Jay, I need to maintain the 3:1 slope for the ditch and 2% for the road.
Steve, that sounds like what I'm looking for. Will try it out this afternoon.
jon_b
in reply to: jon_b
LinkSlopesBetweenPoints solved my problem, and a bit of searching led to a descriptive post and sample drawing on AUGI's forum.
http://forums.augi.com/showthread.php?131725-Help-with-assembly-problem
Thanks Steve, much appreciated!
Rail Community
