Civil 3D Forum
Sub assemblies not displaying
6 REPLIES 6
evanhughes
1382 Views, 6 Replies
Hi all
I have Civil 3d UKIE. Since the installation of service pack 2 the British std kerb appears on the screen as 2circles approximately 2 meters apart.
Any ideas on the cause.
Regards
Evan
6 REPLIES 6
tcorey
in reply to: evanhughes
Check the properties of the subassembly and be sure Omit Link is False.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
niallmiz1
in reply to: tcorey
I am having the same issue with british kerbs sub assembly from UKIE, two red circles appearing in their place. And I can't seem to find any option for 'omit link' in the properties tab. Please can you point me in the right direction?
Niall
craig_robertson
in reply to: niallmiz1
Niall select the subassembly, right click and go to subassembly properties go along to parameters tab and omit link is the last option selected in the image attached.
niallmiz1
in reply to: craig_robertson
Hi Craig,
Unfortunately, in my properties section this is what I'm faced with (see attachment). If it helps, I never had this issue until I installed service pack 2 a couple months ago! Maybe the file path/source is wrong but I don't know how to change it.
SchwartzBwithU
No solution found? Same problem.
AcastelliLPYM6
Try turning on all layers and see if they appear. My "0" layer was frozen and thus I didn't see my subassemblies in model space.
Rail Community
