Civil 3D Forum
Sub Assembly Composer. Why?
8 REPLIES 8
Message 1 of 9
Joe-Bouza
815 Views, 8 Replies
Forgive me. I have not had a chance to look at SAC; mainly because I can't think of what I would do with it.
What can you do with SAC that can't be done with an OOTB component?
Joe Bouza
8 REPLIES 8
Message 2 of 9
Neilw_05
in reply to: Joe-Bouza
The simple answer is you can do things that can't be done with OOTB assemblies.
Fred Ernst had a novel approach for one in this thread: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Civil-3D-grading-for-solar-PV-site-and-golf-c...
Think of a gang of mowers following a dozer that plane and shape the ground. Each mower is linked to the adjacent mower with a link that prevents it from deflecting more than a certain amount. As long as the ground is flat enough the mowers don't change the ground, but if there are steep dips or mounds the mowers lock and cut the tops or (magically) fill the dips.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 3 of 9
klugb
Here is the opposite approach, my first one I created was a very simple daylight subassembly. We just wanted one with basic slope input but allows us to apply +/- to either slope so we can force it to go down even if it is a cut situation.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 4 of 9
mathewkol
Another thing SAC can do is a conditional that measures the cut or fill height at the surface intersection and not vertically at the attachment point. SAC can do a very many things that OOTB subs can do, it's up to your imagination.
You could make a "Road Subassembly" with all other subs essentially built in with switches for the type of curb, SW boulevards, anything. Not that I necessarily advise this, but it can be done.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 9
neilyj666
...but it does require some investment in time to learn to use it which most people have difficulty with....it's been on my "to-do" list since it was first released....
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 9
Joe-Bouza
Thanks guys. I guess I'll work on my imagination 🙂
Joe Bouza
Message 7 of 9
troma
Thanks for bringing it up Joe. Think I'm in the same boat.
Mark Green
Working on Civil 3D in Canada
Message 8 of 9
jmayo-EE
Oh that's funny.
"You'll never grow old if you continue to try new things, continue to learn...and never mind being contradicted."
Think that was Twain. 🙂
John Mayo
Message 9 of 9
Joe-Bouza
in reply to: jmayo-EE
isn't it?
I can remember sailing around the world in a ship built out of the dinning room table with the leaf open for the lower deck and some pillow cases for sails.
But can't think of a different wat to go 3:1 {|:-)
Joe Bouza
Rail Community
