Does anyone out there have a good site that would show how to write VB expressions for the Sub Assembly Composer?? I am new to writing expressions and need a little help.
Jay Meszar
Jay,
There are some great examples in the help file, but if you need more let us know what you are trying to do and we'll see if we can help. I find that for the most part the expressions that I use are pretty simple... P1.X for example to find the x offset of a point.
Cheers,
Peter Funk
can I in SC point take over slope from other point?
point 2 slope = superelevation
point 4 intesection slope point 2 and 3
point 2 slope 1:2
point 3 slope = superelevation
is there a record for point slope like as P1.x for x axis?
I hope I was clear
rename test.zip to test.pkt
When I go to Label Style and expressions and go new Expressions, a separate dialogue box appears to create expressions. Is there a command or way to bring up this expressions builder?
The best reference material to SAC expressions I've found is at the tail end of Kati Mercier''s classroom handouts for her 2011 AU SAC session.
You can get a slope value from a link. Add a link or auxiliary link between the two points that define the slope. Assume the link is L1 - the expression would be L1.slope.
You can also get the slope between two point P1.SlopeTo("P2") without having to add the link
Cheers,
Peter Funk
