Member
taketheblack
Message 1 of 7 (722 Views)
Style Importing
722 Views, 6 Replies
09-14-2012 10:15 AM
In Civil 3D 2013 I'm attempting to import styles from another drawing.  Whenever I select the Import button under Manage > Styles I get a warning box pop up that says "The drawing has unsaved modifications.  Please save the drawings and then perform the style import again".
This occurs even after I hit save or reopen the drawing.  Is there a fix for this issue?
sboon
Message 2 of 7 (715 Views)
Re: Style Importing
09-14-2012 10:52 AM in reply to: taketheblack
You have to start the import command immediately after the save operation.  No pan, zoom or anything else first.
Member
taketheblack
Message 3 of 7 (712 Views)
Re: Style Importing
09-14-2012 11:11 AM in reply to: sboon
I'm not panning or zooming, I'm hitting save and then going straight to the import button, or even hitting the import button straight from opening the drawing.
sboon
Message 4 of 7 (706 Views)
Re: Style Importing
09-14-2012 11:20 AM in reply to: taketheblack
Search the forum - this error has been reported in the last few months.
BrianHailey
Message 5 of 7 (693 Views)
Re: Style Importing
09-14-2012 12:24 PM in reply to: taketheblack
Perhaps you have a lisp routine running that does something to your file immediately after an open or save. I know I used to have on that would modify the drawing when saved and that would probably prevent this command from running (I don't use it anymore thanks to unreconciled layers).
New Member
jamesblyth
Message 6 of 7 (594 Views)
Re: Style Importing
10-18-2012 09:28 AM in reply to: taketheblack
I had the same problem, is your default file save format set to other than Autocad 2010?
Mine was set to 2007 and I think that was the problem, it must run a script to make it compatible after saving which screws up the Import Settings tool.
Try changing that and see if it works.
James.
Member
tar0975
Message 7 of 7 (113 Views)
Re: Style Importing
03-10-2014 12:33 PM in reply to: taketheblack
I am having the same issue as the original poster.  It is default saving to 2013 and I don't believe I have any lisp running in the background.  Any help would be appreciated.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
