My company uses a single block for every storm inlet structure. It is the same size regardless the actual size. I want actual size structures, but am having issues getting there.
I have the blocks for each size, drawn at actual size, but the options under the plan tab in the Structure Style dialog box are cryptic to me. The size options are...
- Use drawing scale
- Use fixed scale
- Use size in absolute units
- Use size as percentage of screen
- Use fixed scale from part size
Why there is no "Use actual block size" option is beyond me. How can I get the structure to appear actual size in both horizontal directions?
From what I gather from reading past threads regarding this issue, there used to be an 'actual size' option, but it has since been taken away.
Solved by Citadel2012. Go to Solution.
I believe that if you use "Use fixed Scale" and set all parameters to 1, the block should appear scaled (1,1,1).
@Citadel2012 wrote:I believe that if you use "Use fixed Scale" and set all parameters to 1, the block should appear scaled (1,1,1).
Ok, now I am embarrassed. I had tried that, because it made sense and everything pointed to that as the obvious answer, and it wasn't working, but I went back and double-checked and... my block was off in one direction. Grrr!
Anyway, your answer is correct. It was my brain fart thwarting me this time. Thank you.
Joe Bouza
