Show only
Search instead for
Okay, I've been racking my brain and spinning my wheels searching for this and I'm finally just going to ask... isn't there a way to reference the connected pipe invert and direction information in the structure label style? I could have sworn I've seen it before, but for the life of me can't figure out how to do it now that I need to. The only thing I can find is "connected pipes", which gives me the number of pipes attached to the structure (which is no help BTW).
Any help or direction would be GREATLY appreciated!
If you click on the new text button pulldown and select text for each, select the structure in-flow pipes then change the text to connected pipe IL, repeat again but use structure out flow.
The 'flow direction' property of the text for each component can return 'IN' and 'OUT' text for you. The 'pipe direction' will return the direction of the connected pipe. (N, S, E, W, NE, SE, SW, & NW)
