When I close C3D 2011 (which I use more often due to the Google image deal in '13), I get the attached pop up box. Has anyone else seen this? It's not disrupting performance, and it only recently started.
Solved by tcorey. Go to Solution.
That happens after you install a newer version. You can fix it with a repair install.
