AutoCAD Civil 3D General Discussion
*Expert Elite*
Joe-Bouza
Message 1 of 26 (413 Views)
Accepted Solution
Station offset reference one label two stations
413 Views, 25 Replies
02-05-2014 12:17 PM
Id like to label Start Station= ##+### to End Station ##+###
can it be done with one label?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
klugb
Message 2 of 26 (401 Views)
Re: Station offset reference one label two stations
02-05-2014 01:01 PM in reply to: Joe-Bouza
Yes sir.
Create one Alignment station-offset label and then add another using the reference text.
See image
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP1)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
*Expert Elite*
Joe-Bouza
Message 3 of 26 (389 Views)
02-05-2014 01:14 PM in reply to: klugb
Thanks Bruce
I must be doing something wrong because I added teh ref text but it give the same station. I sneed a sect pick to give me to ##+### sot the finished product should say
start station #+### to end station @+@@@; two different station same base line
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Mentor
ccoles
Message 4 of 26 (386 Views)
02-05-2014 01:24 PM in reply to: Joe-Bouza
If I understand your question, you want to label a station range with a start station and an end station of the same alignment on a single alignment label. This is possible with an alignment line label. But, I believe it would either need to be a single point-to-point line segment, not a complex line section with multiple PIs and curves, or you'd need to create a sub-alignment that only extends from your start to end range. Then the line label can use the 'Alignment Start Station' and 'Alignment End Station' tags to get what you need.
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
*Expert Elite*
klugb
Message 5 of 26 (383 Views)
02-05-2014 01:31 PM in reply to: Joe-Bouza
No not you. I misread your question. I was thinking you wanted one location labeled with 2 different alignments station/offset.
My bad.
Bruce Klug
Win 7 Pro, 64-bit
*Expert Elite*
Jay_B
Message 6 of 26 (371 Views)
02-05-2014 01:43 PM in reply to: Joe-Bouza
Joe,
Try adding the "Alignment Start Station" and "Alignment End Station" properties to the label.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
*Expert Elite*
Joe-Bouza
Message 7 of 26 (369 Views)
02-05-2014 01:46 PM in reply to: Jay_B
Sorry for misleading you Jay. I'm looking for two arbitray point on the same base line
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Jay_B
Message 8 of 26 (366 Views)
02-05-2014 01:53 PM in reply to: Joe-Bouza
Ah, now I get what your after Pick 2 points anywhere along the alignment and label start / stop stations.
Jay
C3D 2014 SP2
*Expert Elite*
Joe-Bouza
Message 9 of 26 (365 Views)
02-05-2014 01:58 PM in reply to: ccoles
you have it correct, but I trying to compose the label to use in a table. Something like this: I know its bass ackwards but I have the rehab job that wants tables of qty similar to this.  in my plan presentation I typicaly show a hatch pattern in the widen areas. Well I decided to get smart and my curbs are alignments and my sawcut lines are alignments, so I put them in a site and viola automatic/ dynamic hatch.
I knew I couldnt get the stations in a parcel table so I thought station lables can ref the parcels, so I composed the label to be dragged int to table outline, and I'm looking to get the end station in the same label. the other field were easy parcel properties with expressions.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Joe-Bouza
Message 10 of 26 (353 Views)
02-05-2014 02:41 PM in reply to: Joe-Bouza
For now I settled on two labels. its not my favorite but full steam ahead .. **** the torpedoes!
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
