How do I modify the leader for station and offset lables to underline the top line of text?
You can set it up to be underlined in the Layout tab and then set the text to display 'As Composed'
Mark Green
Working on Civil 3D in Canada
underline works with stacked text also. and with stacked text you can drag it left right up down and the leader stays attached to the side you want.
