augdog all the above comments are true and can get what you desire. Since
you're an old Eagle Point user you will obviously find some differences in
how Civil 3D works vs Eagle Point. We have created a Surveyors' Companion
product that is a complimentary add-on to Civil 3D that not only helps old
Eagle Point users but all users when it comes to certain surveying tasks.
In this particular case the station offset report that you used to run in
Eagle Point was brought over and is the same in Civil 3D. I just wanted to
make you aware of the Surveyors' Companion and that it may help you take
advantage of Civil 3D faster. If you want to talk offline please shoot me
an email. (steve dot biver at eaglepoint dot com)
wrote in message news:6387256@discussion.autodesk.com...
In Eagle Point you could always print a report of your survey points showing
your station & offset from your alignment. Can and how do you do this in
Civil?
