Civil 3D Forum
Station Label Style
5 REPLIES 5
154 Views, 5 Replies
Station Label Style
Is it possible to create a station label style like:
10~ instead of 10+00?
If so, how can this be done?
Sgrisez
5 REPLIES 5
It looks like you have only a few choices. See attched. "Sgrisez" wrote in message news:31026250.1106679784620.JavaMail.jive@jiveforum1.autodesk.com... > Is it possible to create a station label style like: > > 10~ instead of 10+00? > > If so, how can this be done? > > Sgrisez
Sgrisez, You can do that with Civil 3D. In the Major Station Label Style, change the format of the string from "Station Format" to "Station Index Format", change the rounding to "Truncate" and the Station Character to "" and then add a "~" at the end of the string. When you're done it should look like the attached screen shot. Peter Funk API Product Manager Autodesk, Inc. "Sgrisez" wrote in message news:31026250.1106679784620.JavaMail.jive@jiveforum1.autodesk.com... > Is it possible to create a station label style like: > > 10~ instead of 10+00? > > If so, how can this be done? > > Sgrisez
Yes. Station Index Format can make 10+00 But Last Station is not show exactly.
for Example Last Station is 10+10.34 but Civil can not show this.
If I make rise up decimal, all station is change 10+00.00
Peter,
Thanks. This gave me what I needed.
Stephen
Thank you Peter, you helped me with my Problem, which was not the same, but your instructions worked for me also
Rail Community
