Civil 3D Forum
State Plane Coordinate in C3D 2006
3 REPLIES 3
tom starkweather
145 Views, 3 Replies
I am having trouble getting a handle on setting up C3D to deal properly with importing state plane coordinate points. If I set up a blank drawing with a template that is set with our local settings, with a transformation from grid to local coordinates, I can't seem to get the proper information to be accepted by the program and I get bogus coordinates listed. Then, if I the wrong info is taken by the program, it won't let me change it to the correct numbers. The infor I am importing comes from our GPS processing software and is output as grid coordinates and I can't seem to get C3D to recognize them as other than local coordinates, it then creates a grid coordinate from the grid coordinates. Is there some way to get C3D to understand that the imported points are already grid? I have tried to create a new import format that will show this but C3D won't import anything from the point file.
Tom.
3 REPLIES 3
in reply to: tom starkweather
I am not sure if I understand your question correctly. Also I do not use
Civil 3D but do use Map so I will do my best to answer what I think is the
question.
From what I understand your GPS unit is giving you Lat and Long coordinates
and you wish to convert them to State Plane. This is how I would do that.
1. First bring the data from you GPS unit into a new drawing. Some GPS units
will export directly to DWG or DXF formats. If so just open that file.
2. Once you have the data open, then assign it the correct Lat and Long
projection. I believe most GPS units use WGS 84 but you will want to verify
that.
3. After assigning the correct Lat and Long projection save and close the
drawing.
4. Open a new blank drawing and assign it the proper state plane coordinate
system
5. Attach the drawing with your GPS data in Lat and Long coordinates
6. Create and execute a draw query for your GPS data. I usually do it by
location and select all.
7. Detach the original drawing and then save your new drawing which should
now contain your data in state plain coordinates.
I hope that helps.
Tripp Corbin, GISP, MCP
Associate Vice President, GIS/Mapping
ESRI Authorized Instructor
Keck & Wood, Inc.
www.keckwood.com
(678) 417-4000
(678) 417-8785 Fax
Keck & Wood now offers Introduction to ArcGIS training classes. Contact me
for more information.
wrote in message news:4893781@discussion.autodesk.com...
Tom.
Thanks for responding, Tripp.
I am trying to learn how to do this in C3D. I have an ASCII file with state plane coordinates in it. I am attempting to import using the methods I know about in C3D. I have tried to set up an import points format to accept the coordinate pairs as state plane, like I have done in LDD, but C3D just won't import the points and doesn't give me any idea why it doesn't. I guess I am looking for someone that has figured this out already. It shouldn't be as complicated as your method in Map.
Thanks.
Tom.
You are the first person I've seen here who is actually addressing the idea that ground coordinates differ from grid coordinates. Most people simply translate the points and don't apply a scale factor. I have found that if you first import the points as ground, then import the same file with a grid import format and overwrite the previous points, they will import properly. Are you using the prismoidial computation for your transformation? I work with TIFF as well and in LDD2005 the transformation would be applied when using Raster Design. Unfortunately it does not appear to be working with Civil 3d.
Rail Community
