Civil 3D Forum
Start C3D 2015 without Tab screen
4 REPLIES 4
neilyj666
984 Views, 4 Replies
How can C3D 2015 be started in the normal i.e. 2014 way without the Tab screen?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
Type "Startup" on the command line and set the value to 0.
check here http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-941B7406-2342-47EA-9881-BAFF3A554310
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Thanks - I may get used to the Tab startup eventually...;)
Cadguru42
in reply to: neilyj666
That's actually one of the new features that I use the most so far with 2015. It's faster to choose a new drawing based on a template or open recent drawings because you don't have multiple dialog boxes.
Can't say much else about 2015 because it hardly works, but when it does it's great! 🙂
C3D 2022-2024
Windows 10 Pro
32GB RAM
neilyj666
in reply to: Cadguru42
May have been a bit premature turning this off - I've turned it back on and I'll See how it goes
Rail Community
