I know this is an old topic, but here in 2014 I'm just wondering anybody has a better way of doing this other than feature lines or faces? thanks.
No better way I know of. It all depends what you want from the stairs. When I have to do a wall for grading but don't have to worry about quantities. I make a separate surface, construct the wall from featurelines and add them to the new surface. Then I can label elevations and create points at the surface elevation.
There's no Create Steps routine in Civil 3D. If you need quantities then use the Alignment, Profile, Corridor suggestion.
Allen
Allen Jessup
CAD Manager - Designer
In my case, I'm working on existing ground.... fyi.
To build stairs from feature lines, every stair has to be in separate site.
Vertical feature lines can't be created.
What I wonder is that you cant really even edit feature lines in model view direction.
A decent stairs and retaining wall tool is badly missed in Civil.
