Hi all,
Has anyone run into the problem where is you have stacked tables any they
overlap in layout tab? Here's what I do to reproduce this MANY times over:
I have a layout with my plan. I used the 3D FREE ORBIT to graphically see
what I wanted the plan to be rotated to. I have my tables generated in model
space and I want to make an additional viewport of just those tables.
1. In layout tab, I make a new viewport.
2. I DVIEW TWIST the viewport to zero so that the tables come in properly.
3. I set the viewport to the desired scale (1"=100'). All looks good so far.
4. I do a REGENALL and now the tables all overlap each other!
I played with the spacing between tables which didn't seem to help. On a
side note, if you have the view in a different twist scale, the tables are
all stepped from each other. Strange! So if anyone has any words of
encouragement, I'd love to hear from you.
Rick
C3D 2007 SP3
Dell DuoCore 2.66GHz 2GB Ram 256 Dual DVI Dual monitors!
Rick
coauthor Mastering Civil 3D 2012
I blog at http://simplycivil3d.wordpress.com
