OK, so I decided to try to get the view of the site off of rotation by doing
a DVIEW TWIST 0. I then made a new viewport for for the tables, regened and
all is fine now!!
I'm wondering if the 3D FREE ORBIT command does things differently than
doing a DVIEW TWIST? I don't seem to remember having any problems with this
when I did the plan in a DVIEW TWIST. I learned about the 3D FREE ORBIT at
AU in Lucy Kuhn's class.
wrote in message news:5428821@discussion.autodesk.com...
Hi all,
Has anyone run into the problem where is you have stacked tables any they
overlap in layout tab? Here's what I do to reproduce this MANY times over:
I have a layout with my plan. I used the 3D FREE ORBIT to graphically see
what I wanted the plan to be rotated to. I have my tables generated in model
space and I want to make an additional viewport of just those tables.
1. In layout tab, I make a new viewport.
2. I DVIEW TWIST the viewport to zero so that the tables come in properly.
3. I set the viewport to the desired scale (1"=100'). All looks good so far.
4. I do a REGENALL and now the tables all overlap each other!
I played with the spacing between tables which didn't seem to help. On a
side note, if you have the view in a different twist scale, the tables are
all stepped from each other. Strange! So if anyone has any words of
encouragement, I'd love to hear from you.
Rick
C3D 2007 SP3
Dell DuoCore 2.66GHz 2GB Ram 256 Dual DVI Dual monitors! 🙂
