Civil 3D Forum
Spot Levels at decimal point
2 REPLIES 2
neilyj666
424 Views, 2 Replies
I've got a cut./fill plan with red and green surface spot level labels (derived via a grid) but wonder if there is a way to make the decimal point coincident with the with "X" marker (see screenshot)
I'm sure I've seen a technique to do this but can't find it
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
2 REPLIES 2
Jeff_M
in reply to: neilyj666
Use 3 components in your label. Decimal point connected to Feature-MiddleCenter, left of decimal, right of decimal.
neilyj666
in reply to: Jeff_M
Thanks Jeff - I did it slightly differently (I think) but you pointed me on the right track ...:)
Rail Community
