AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 8 (355 Views)
Accepted Solution
Spot Elevation - Distance between PVI's?
355 Views, 7 Replies
10-22-2011 12:03 PM
Im using Civil 3D 2012.
I want to show the distance between Profile PVI's on a Surface Spot Elevation.
Possible?
*Expert Elite*
Joe-Bouza
Message 2 of 8 (351 Views)
Re: Spot Elevation - Distance between PVI's?
10-22-2011 02:06 PM in reply to: kevinjackman
You can add profile data to alignment labels that show stations. Some finessing the style may get the desired results.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Message 3 of 8 (338 Views)
10-23-2011 08:17 AM in reply to: kevinjackman
I can add profile data to a spot elevation label without issue but i can't calculate the length between pvi's.
Message 4 of 8 (294 Views)
11-01-2011 08:00 AM in reply to: kevinjackman
Any of you label experts out there have the answer?
*Expert Elite*
Joe-Bouza
Message 5 of 8 (288 Views)
11-01-2011 09:15 AM in reply to: kevinjackman
Yes. use a featureline with a label style the shows the end elevations and distance between. Set the FL style to NoShow or NoPlot
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Message 6 of 8 (276 Views)
11-01-2011 10:50 AM in reply to: Joe-Bouza
Thanks Joe.
*Expert Elite*
Joe-Bouza
Message 7 of 8 (268 Views)
11-01-2011 11:25 AM in reply to: kevinjackman
HTH. Sometimes it takes a fresh look, and pulling out that stubby phillips head screwdriver the hardly gets used. :smileywink:
I see you also got the grade in there, nice.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Joe-Bouza
Message 8 of 8 (267 Views)
11-01-2011 11:27 AM in reply to: kevinjackman
another way I have used is to create a FL from an alignmentent. and you can use alignment label styles to label pgl in plan
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
