Civil 3D Forum
Spot Elevation - Distance between PVI's?
7 REPLIES 7
Message 1 of 8
kevinjackman
725 Views, 7 Replies
Im using Civil 3D 2012.
I want to show the distance between Profile PVI's on a Surface Spot Elevation.
Possible?
Tags (1)
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: kevinjackman
You can add profile data to alignment labels that show stations. Some finessing the style may get the desired results.
Joe Bouza
Message 3 of 8
kevinjackman
I can add profile data to a spot elevation label without issue but i can't calculate the length between pvi's.
Message 4 of 8
kevinjackman
Any of you label experts out there have the answer?
Message 5 of 8
Joe-Bouza
Yes. use a featureline with a label style the shows the end elevations and distance between. Set the FL style to NoShow or NoPlot
Joe Bouza
Message 6 of 8
kevinjackman
in reply to: Joe-Bouza
Thanks Joe.
Message 7 of 8
Joe-Bouza
HTH. Sometimes it takes a fresh look, and pulling out that stubby phillips head screwdriver the hardly gets used. Smiley Wink
I see you also got the grade in there, nice.
Joe Bouza
Message 8 of 8
Joe-Bouza
another way I have used is to create a FL from an alignmentent. and you can use alignment label styles to label pgl in plan
Joe Bouza
Rail Community
