Attached is a screen capture of the issue I am encountering.
For some reason unkown to me, I am not able to create split views, as the option to select the profile style is not displaying. I am using the correct profile style, which I have imported both from my template and another project where the split views work. Any suggestioins as to why this is occuring and how to resolve it, as it has occured on more than one occassion. I have created a new drawing from a template and data referenced in the alignment and profile, still have the same result. Not using a split view does work, so I do not beleive there is an issue with the data.
Keith Biggs Chair,
CAD Committee & Senior CAD Technician
R.F. Binnie & Associates Ltd.
Leading in Quality: OQM certified March 2013
I can use select the + button to pick the station and elevation, however, the dialogue box does not display this data. Also, the profile view does split, however, the grid lines in the profile view are not displaying, on the text and the surface profile. The spilt view style I have does work, as I imported it from another drawing. The odd thing is, if I use a different template and create the split profile view it works, however, it does not work with one particular template.
I may have to recreate this template to see if that resolves the issue.
Keith Biggs Chair,
nothing, I tried using a differnt profile view style in the template, same result. Must be an issue with the template I suspect.
Keith Biggs Chair,
Have you tried wblocking in this problem file where it won't work into your clean dwt?
Yes, still the same issue, which leads to believe it can't be the template. It can't be the data, as this occurs on multiple alignments from the same project.
Keith
