Civil 3D Forum
Span Labels
10 REPLIES 10
Message 1 of 11
bmossman
201 Views, 10 Replies
Span Labels
Where do you control the spanning for Tags of an alignment in 2007?
10 REPLIES 10
Message 2 of 11
kcobabe
in reply to: bmossman
If you mean how often it will be in the label sets next to the label style name.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 3 of 11
dana.probert
For some insight into why/how span labels work (and don't work) see my post at www.civil3d.com
direct link:
http://www.civil3d.com/index.php/2007/01/the-art-of-the-span-parcel-labeling/
dana breig probert
www.civil3d.com
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
Message 4 of 11
I can get the labels to display the correct distance when spanning outside segments, but sometimes we use crows feet which are anchored to the direction arrow for lines... but the direction arrow doesn't seem to span outside segments. I have turned the span toggle to "true" for direction arrow before anyone asks ; )
Message 5 of 11
dana.probert
gothcha.
I'll post more at civil3d.com later today, but basically, this one is hit or miss.
try this:
1 reverse the label that won't span the crows feet
2 flip the label that won't span the crows feet
3 all else fails, make child styles for 'start crow foot only' and 'end crow foot only' then label separately
but I will run thru some of the scenarios that give me trouble and the solutions I've found in a blog post later today
dana
Dana Probert, P.E.
Message 6 of 11
mmccall
Try giving your direction arrow a small Y offset from the segment.
Message 7 of 11
dana.probert
I'll be damned.
Dana Probert, P.E.
Message 8 of 11
dana.probert
I documented it here
http://www.civil3d.com/index.php/2007/01/the-art-of-the-span-crows-feet/
and I gave your credit, MMcall. You Rock.
Dana Probert, P.E.
Message 9 of 11
mmccall
yeah, I don't quite understand why it works but it does.
My only guess it that at some level the coordinates of the lines are being rounded and it's causing the end of an intersecting line to calculate as being over/crossing the segment being spanned. Pushing the direction arrow to one side gets it past these little overshoot calculations.
Message 10 of 11
dana.probert
i'm betting it is like the curve label span where if it isnt far enough away from the "wrong" side (ie the side with the split face vertices- see my post on www.civil3d.com from last night) it has an identity crisis. the little offset throws it into the right mindset.
Dana Probert, P.E.
Message 11 of 11
mmccall
:o) ... always happy to help.
Rail Community
