Civil 3D Forum
Some Desc Keys wont work
4 REPLIES 4
yazzie91
330 Views, 4 Replies
I am drawing up a topo survey and some of my DescKeys wont work. Most of them work, but some just dont. My J-BOX, PWR RISER and gate post. Attached is an image of my desckey and point. Am I doing something wrong?
4 REPLIES 4
timreed1
in reply to: yazzie91
Get rid of all spaces in your raw descriptors and keys.  Replace them with underscores or dashes.
Standardize on all CAPS too.
awood
You might also look for any conflicts in your DescKeys with wildcards - say if you have a key as J* or P* those would be used first and J-BOX and PWR RISER would be ignored.
Double-checked the Point File as well to make sure it's using the right field codes.
HTH
AWood
yazzie91
Thanks! Using the under score worked. So dashes, spaces and lower case point descriptions wont work with the desckeys?
IanMcClain
The description key uses space as a delimiter between fields, there is no option to change that. Anything else is seen as a part of the description/field.
Ian McClain
Rail Community
