Active Member
MJR_PE
Message 1 of 3 (136 Views)
Some Assembly required
136 Views, 2 Replies
01-28-2014 04:46 PM
It might seem obvouis to most but i can not get my contours in the corridor to recognize the curb line or the centerline of the road. Assembly is shown below a snap shot of the section view.
Curb on both sides, sidewalk only on one side. I have a crowned road section with 2% slopes and I used the basic curb & Gutter sub-assembly with a 7" reveal. This has never happened before and I hope it is a simple solution.  Anyone encounter this?
Joe-Bouza
Message 2 of 3 (120 Views)
Re: Some Assembly required
01-28-2014 05:38 PM in reply to: MJR_PE
Right click the corridor>>> corridor surface>>> on the surface tab select overhang correction.
your did pick top links to build the surface, right?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Member
MJR_PE
Message 3 of 3 (84 Views)
01-29-2014 08:14 AM in reply to: MJR_PE
Thanks. I had NOT had TOP links.  I knoew it would be easy for someone. Thanks again.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
