Hi friends,
I have one cross section, which gets narrow over the particular length.
(C/S : Elliptical roof surface)
In the region where cross section changes, triangulation becoming weired. If we edit surface with swape edge command then it will be ok.
I have attached both the images before and after swapping for ref.
Can we do this by dyanamically ? as I have number of areas like this.
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Joe Bouza
Now I have added feature lines to surface definition, that works perfect. Thanks for remembering basics of triangulation.
