So I've built a surface and now need to do a slope analysis. I've gone trough the surface style and done my slope analysis by shading, set my variables from 15-18, 18.01-25, 25 and up set my shading colors. I go to turn on my slopes and it looks good except everywhere under 15% is a solid white hatch. Can anybody figure out how to get rid of it. I've played with the settings and can not figure it out.
Any help is much appreciated
What version of Civil 3d are you running? Also, it might help to post a screenshot of your problem, a picture of surface properties> analysis tab> slopes, and a picture of surface style> analysis tab> slopes.
I'm running 2014 Civil 3D. Here are the screen shots of the listed displays. I'm new-ish to civil 3D but I just can't locate where turn the soild white hatching off. I'd be alright if it just did not print.
Thanks for the help.
Maybe someone will chime in with better info but I believe this is a known issue that has yet to be fixed. If you do not all of the product updates installed install them. If you need to print this creat a range for the slopes less than the 15% and assign a color that will not plot.
John Mayo
