Civil 3D Forum
Single Errant Corridor Section in Cul De Sac
2 REPLIES 2
363 Views, 2 Replies
See the attached image.  I have a single corridor "section" that extends from the 'tip' of my cul-de-sac back to the start of the alignment.  Any thoughts on what is causing this?
I scoured the group before posting and didn't see anything quite the same.
Would it have something to do with the corridor line being parallel to the alignment?
Thanks.
2 REPLIES 2
sboon
More than likely.  Can you delete the offending corridor section?  Another option may be to edit the centerline alignment to add a very small circular segment at the center of the culdesac, so that the corridor can target it properly.
Steve
Expert Elite Alumnus
I ended up splitting the baseline into two regions to solve this.  I created two regions with a 0.1' gap to avoid the point where the alignment was parallel to the offending corridor section.  It 'worked' but might not be the preferred solution.
Rail Community
