Hi everyone,
Can you tell me where is the option to modify the quality of a surface tham I'm displaying?
For instance if I zoom out, it looks with less polygons, if I zoom in it looks with more polygons.
I've downloaded today some DEM Surfaces with an area of an entire city, and the civil 3d is simplifing automatically the surface... I gave a friend the same surface and on his civil 3d it works very bad without simplifing the surface at all.
I guess there has to be a switch somehere?
Solved by Alfred.NESWADBA. Go to Solution.
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
if you look to the NewFeaturesWorkshop you will have seen that as a new option for Civil3D 2012, with the goal of a really better performance on screen.
The command therefor is _AECCLEVELOFDETAIL to switch it on or _AECCLEVELOFDETAILOFF to switch it off (>>>details<<<).
[EDIT] to late, have to get coffee to speed up 😉 [/EDIT]
- alfred -
Mark Green
