Does anyone know the differences Simple vs Regular Cooridors. Any literature would be helpful. There are a few engineers and techs I work with and they use Simple Cooridors. Myself and others use the Regular Cooridor. I have figured out the difference between the two. Thanks.
James E McClendon
CADD Tech
Solved by Jeff_M. Go to Solution.
THere is no difference in the corridors themselves. The only difference is the amount of information prompted for to create them. From the help on creating corridors:
Use the Create Simple Corridor command to quickly create a basic corridor.
Use the Create Corridor command to specify complex parameters at creation time.
Thanks for the reply Jeff,
So, correct me if I'm wrong, if I create a cooridor from "Simple Cooridor", I'll be able to make complex modifications to it as I would when I created a cooridor from the "Regular" cooridor.
