Civil 3D Forum
Simple Render Question
3 REPLIES 3
torpedo99
283 Views, 3 Replies
I've used C3D for several years for roadway design but never got around to rendering anything, now I have a need.  Currently using C3D 2011.
When I try to assign a pre-defined Render Material to a surface via the Surface Properties Information tab no rendering occurs.  There are several (looks like Autodesk stock) rendering materials but nothing seems to happen when I select them, the surface does not change it's appearance to rendered.
What could it be?
3 REPLIES 3
Neilw_05
in reply to: torpedo99
Do you have your view style set to one that shows materials (i.e. Realistic)?
While you can display materials with view styles in C3D, "rendering" usually entails applying light and shadow settings and textures to produce photo realistic views of the models, so it is a more involved process. Is that what you are after?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Joe-Bouza
Ditto what Neil says
Joe Bouza
torpedo99
in reply to: Neilw_05
that was painless, thanks!
Rail Community
